CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
01 DS650 Help Please,,,Starts sometimes??
Old Oct 5, 2009 | 05:37 PM
Gatorbone's Avatar
Default 01 DS650 Help Please,,,Starts sometimes??
Hey guys i'm new here looked like a great forum! I have an 01 DS650 starts sometimes maybe runs for a min to 10 min then acts like its starving for fuel then dies & won't start Even with gas or carb cleaner directly in carb while cranking, So this tells me its not a fuel problem & kinda seems electrical to me, it;s Got a new battery & yesterday I went out it started right up rode for about 10 min like it should then crapped out, now I started it it idled barely reved then stalls, who know next time it could run fine again seems unpreditable....ANY HELP WOULD BE GREATLY APPRECIATE!
Old Oct 5, 2009 | 06:01 PM
BigCquadguy's Avatar
Have you had the Carbs cleaned out. If you've had it set to long at times with out turning the fuel off the fuel could be clogging the jets with gunk, also make sure stator wires arn't being pinched. and make sure your fuel tank is breathing. Ensure the fuel line isn't piched either. Goodluck.
Old Oct 5, 2009 | 06:17 PM
Gatorbone's Avatar
Thank for your help I will check that stuff out tomorrow!
Old Oct 7, 2009 | 12:13 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Do a leakdown test - this year is bad about breaking the rings ... among the previously mentioned
Old Oct 8, 2009 | 03:27 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Try cracking the gas cap open when the problem starts to happen - that will tell you it is a pinched off vent line. It happen to me a few years ago - took me a while to figure that one out.
Old Dec 31, 2009 | 08:14 PM
2K650's Avatar
I have a 2k 650 starts kind of rough usually have to choke and spray starting fluid. Sometimes it will run like a top, lately it has been bogging,sputting, just when I simply try accelerating then usually cuts off. Could it be cdi box, rectifier regulator, spark plug wires, or simply clean the carb. Please help deeply appreciated
Old Jan 4, 2010 | 09:19 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Clean the carb and put some new plugs in it and then see.
1000gade
May 27, 2015 12:37 PM
need4aquad
Feb 4, 2001 03:26 AM
vernl
Jan 7, 2001 08:13 PM
2punksdad
May 23, 2000 01:46 AM
hot_shoe_cv
Oct 12, 1999 08:32 PM
