Got my hmf pipe today
Anyone havve any takes on jetting. I live at 400 feet above sea level. Right now I have a modded end cap with 190 mains jet from a dyno jet kit and THe needle in the fourth clip , K and N filter in the box with the lid off. Ron woods rev limiter. Any suggestion any one. I feel like I should be close to the same jetting.
I have almost the same set up. You should be just about dead on. One way to check is take the bike for a good hard run and pull the plugs. If they are a nice tan color your right on. Black means your rich and white means your lean. Hope this helps.
Originally posted by: fastone21
the spring that racer is refering to is the vacum slide spring on top of the carb that goes above your needle.
OK, so when you cut it what does it do? how much do you cut it off?
mrtidy
Feb 3, 2016 05:00 PM
greg86hd
Sep 16, 2015 12:32 AM
