best gearing for trails,dunes and high speed
Old Jul 9, 2003 | 04:37 AM
Hightower's Avatar
Default best gearing for trails,dunes and high speed
the pump will cure it for sure Tyre - well worth it. it gives violent and explosive acceleration, you're gonna love it.
Old Jul 9, 2003 | 03:28 PM
fastone21's Avatar
get a lectron or trik out the stock carb
Old Jul 9, 2003 | 10:39 PM
Hightower's Avatar
neither can compare
Old Jul 9, 2003 | 10:58 PM
lilnotts's Avatar
wat do you mean trik out stock carb?
Old Jul 9, 2003 | 11:08 PM
  #15
PUSHINTHELIMIT's Avatar
He means do all the tricks lilnotts. [img]i/expressions/face-icon-small-happy.gif[/img] spring, vacume ports, and perfect jetting!!
Old Jul 9, 2003 | 11:11 PM
  #16
ironrod's Avatar
Ditto
Old Jul 9, 2003 | 11:16 PM
  #17
TyreSpinner's Avatar
Wonder how much a control rod sells for?
I don't know if you guys know...but the TM45s that come from RWR (I have the older style tm45), all I need is the control rod to enable it right?
I know I have the plactic A/C pump assembly and the spring, and the adjustment screw. Not sure if I have the plunger and all that. Do they normally come with it?
Old Jul 9, 2003 | 11:32 PM
  #18
lilnotts's Avatar
don't you drill out the vacumn ports? if so wat size?
Old Jul 10, 2003 | 12:12 AM
  #19
pudjumper's Avatar
I believe I read in this forum not so long ago .125".
See.....
http://forums.atvconnection.com/mess...ighlight_key=y
JMiller
Old Jul 10, 2003 | 12:15 AM
  #20
DCryder's Avatar
lil, i heard 1/8". I did it and it works fine.
hightower, wonder what the speed rating is on knobbies?
Frisky2050
Apr 9, 2020 11:19 AM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
sara durrant
Jul 6, 2015 05:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
