looking for quick help on a tm 45 mm carb
Old Jul 13, 2003 | 10:52 PM
DStroyer's Avatar
Default looking for quick help on a tm 45 mm carb
Hello all,
I just installed the tm 45 mm carb and I have a problem. There appears to be a vent fitting on the upper right side of the carb in front, but there does not seem to be a vent tube anywhere that would fit in that position. The instructions call out 2 vent tubes to run to the rear and down, but there seems to be a third on this carb, with no info on it. Can anyone please help, im in a bind.
Gary
Old Jul 13, 2003 | 11:28 PM
Birdoprey's Avatar
If it faces towards the intake/head(straight foreward), then it needs to be capped. Its a vac source. Prolly why you are running lean....
Old Jul 13, 2003 | 11:35 PM
Domi's Avatar
is the choke just above this vent? I checked mine out and it is blocked off with a rubber cap.
Old Jul 13, 2003 | 11:40 PM
Birdoprey's Avatar
Actually, there is two on the front of the carb. Both should be capped(the lower one prolly is already, the top is prolly the one that is'nt).
Old Jul 13, 2003 | 11:57 PM
DStroyer's Avatar
Got it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks a million guys, the project is coming together.
Race Cams, tm45 carb, titanium valve springs, ported head, high compression piston, 60% clutch springs, Alba race pipe, and some good old 104 octane go go juice.
Mr. Broke
Old Jul 13, 2003 | 11:58 PM
Domi's Avatar
Who did you head? DStroyer
Old Jul 14, 2003 | 12:32 AM
Birdoprey's Avatar
What kinda compression ya running? My head is being ported as i type(well, maybe not right this minute!). He is starting on it tomorrow. I have hopes of a GOOD hp gain with this head. The fella porting it works for the IRL(Indy Racing League) and he ports and flows heads for a living. His shop(the shop he works for, that is. He ported the head) built the motor that won the 1998 Indy 500. We shall see....
Old Jul 14, 2003 | 01:08 AM
DStroyer's Avatar
Hey guys,
The head was done by Alba. They really opened up the exhaust and intake and polished. I forgot to mention, I also have the RW cdi box. The piston is a 11.5:1. I thought I would start with this one for now. Next winter project is the dual carb set up along with the big bore kit and oversized valve job with the 13:1 piston. I think my arms will end up 2 inches longer. Im heading to Silver Lake in Michigan this comming weekend, so Im hoping to get onto a dyno before I go.
Thanks again for all the help, thank god for this forum,
DStroyer
Old Jul 14, 2003 | 02:12 AM
Domi's Avatar
nice!!!!!!
GregM
Mar 6, 2018 06:53 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Aitch
Jul 21, 2015 09:40 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
