having 1000 to spend
Old Jul 15, 2003 | 04:27 PM
  #21
ironrod's Avatar
Default having 1000 to spend
Tony,
If you re-program your curves, then yes, you do have to be careful. But, I have heard of no one with any problems with the vortex CDI "out of the box", including myself. If you are going to screw with the timing, you betting know what you are doing. The pre-programmed timing curves in the Vortex CDI are all good. The only need to re-program some of the curves is to eliminate or change where the rev-limiter is.
Marky
Old Jul 15, 2003 | 05:13 PM
  #22
fastone21's Avatar
okay guys I will start ordering parts. But for the final answer is if I have to run race gas might as well run as much compression as possible. so are you guys saying piston and cams and doing port work later. Is there anything I can do to the head myself. I have good experience with cars and bikes.
will this work
A1 A2 cams
14.1
headwork and a lectron ( running out of jets for stock carb)
what is the head porting turn around.
Old Jul 15, 2003 | 07:20 PM
  #23
ironrod's Avatar
fastone21,
The 14:1 piston, and A1A2 cams are a good choice. Dont forget to add in performance valve springs. You can get them from Web (the shim under bucket kind), or Ron Wood Racing (good but you float the valves and you are taking chances). As far as head porting, my mechanic did mine in about a three week turnaround, once he got them. But, everyone else had thier own times.
Marky
Old Jul 15, 2003 | 10:49 PM
  #24
SANDMAN430's Avatar
will that 14-1 run the a-1 or does it end at 425? if you can go the race gas the higher the compression the better[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 15, 2003 | 10:59 PM
  #25
ironrod's Avatar
You can run either cam with the 14:1 right up to the Race II cam. Yes, you must run full 110 race gas to run the 14:1. Say bye bye to cheap gas! - But ZOOOOOOM!
Old Jul 15, 2003 | 11:28 PM
  #26
SANDMAN430's Avatar
ironrod you could go to northwect solvents in eugene and buy a 55gallon barrel of 120 and mix 3 and two super it give about a 109 mix, the barrel is $231 or it was like 201 for a barrel of 110
Old Jul 16, 2003 | 12:35 AM
  #27
ironrod's Avatar
Thanks! I suppose if I wanted, I could buy a barrel of 110 race gas at wholesale too. But, I think a barrel of that sitting around is probably not a good thing either.
Old Jul 16, 2003 | 10:13 AM
  #28
fastone21's Avatar
who's the man when it comes to port work.
Old Jul 16, 2003 | 12:53 PM
  #29
TyreSpinner's Avatar
OMW racing I heard does some good porting. (Mister HP)
Old Jul 16, 2003 | 01:13 PM
  #30
fastone21's Avatar
do you a contact for him and how much do he charge.
