Clutch Problem Again.
Old Aug 4, 2003 | 01:16 PM
DuneMe's Avatar
Default Clutch Problem Again.
new stock clutch baskets are about $50. . . my buddy broke off a clutch spring bolt in his and just got a new one. You can probably have his old one if you want but, probably best to get a new one.
Old Aug 4, 2003 | 01:49 PM
SANDMAN430's Avatar
i had a actuator problem about six weeks ago so i put a new one in did it in the field in about 30 minutes, well in my haste to ride i overlooked a few things like the shaft that turns on the actuator must have turned and got debris in there that i didn't clean out, or something any ways it damaged the shaft and i went to race and found i didn't have much of a clutch, so when you are in there you may want to pull thet shaft out and check it, i don't think that is the problem you are having but while your in there you might want to check.
Sjrpp
May 2, 2023 03:59 PM
coolguy420
Jul 10, 2015 01:17 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
