Who installs oversize vavles?
what do you mean kill pulse rate for that turbo?
i was told one reason the intake valves are larger than the exhaust valves is to create a vacuum for basic carburetor action. this vacuum isn't needed for fuel injection.
i was told improving things on the exhaust side would have a large impact on power. the reason being that with all the boost on the intake side, i have increased the flow a ton there, but have done nothing to improve flow on the exhaust side.
right now the head is stock with stock cams.
i was looking at larger intake and/or exhaust valves, different cams, larger bore, same stroke.
the turbo is a little big for the motor. i was told becuse of this, more cam would help. if the turbo was small, stock cam or less would be better. when i have retarded the intake cam, i made more peak power and it held longer.
the throttle body is dual 40mm, the intake manifold is matched to stock head w/35mm ports.
i run methanol, but haven't done anything with ignition timing other than woods CDI. i have a Vortex on the way. i lowered compression to 8:1. the vortex will have more timing on the bottom end.
jrooker6
04-23-2016 07:36 PM
