How do i permanently remove my fan?
Ok guys this is the scenerio. My fan has not run since silver lake 2002 and i want to remove it. I am running liquid ice and rad schroads(sp?) i have the unit removed from the radiator but i am not sure where to disconnect it. shoud i just cut it @ the fan itself or is there a better way than to just jerry-rig?
thanks in advance
thanks in advance
The wires you want to disconnect are up under the left side of the fuel tank, right along side the frame. It is a plug in type connection. No need to remove the tank or anything to get to it either. I would suggest filling the plug connector with sylicone or something.
