Anybody have a rear carrier diagram???
According to the parts diagram there is one on both side.
I was going to post the diagram for you but I have to upload the entire pdf file and that 8 megs in size. Right now the net is real slow being a Sunday evening and all. Dial up doesn't help.
I'll try again in a while. If I can get an upload speed of at least 4k then i'll do it. But this 1.7 crap right now aint cutting it.[img]i/expressions/face-icon-small-sad.gif[/img]
Check the original post date. I didn't. I read this this afternoon and went out to see if I could see what you were talking about. I ended up taking the rear all apart and replaced the bearings and seals. I replaced the o-ring inside the brake hub.
There was only one o-ring around the carrier. It was for the brake bracket on the left. I didn't have that o-ring. I did the heating the carrier in the oven thing and the bearings in the freezer. It worked.
There are these little metal wear sleeves. They are a pain in the a$$ to get off. I used the two old seals together and a 2x4 to beat the new one on. I didn't even bother trying to take the one on the sprocket side off.
God I hope I did it close to right. I don't have the crow foot tool to properly tighten the pre load nut. I hope I was close. I tightened the heck out of it then backed it off and spun the axle around a little and then re tightened to what I hope is right.
LOL..I just noticed that this post originated several months ago. I expect you already have the info you need by now....lol
But just in case anyone else whats the info.http://www.ljsoftware.com/DS/tcp0102af.pdf Please save this to your computer rather than keep on downloading and looking at it. That uses a lot of my bandwith. Saving it once to your computer will help you as well. Thanks
