EGT sensor on alky
I just got my DS runing on alky, and it runs good, very fast. The only thing is that it seems to have a flat spot from half to full throttle. I know I cant check the plugs so does this mean lean or rich, should I change the main or needle position, and up or down. I am now runing a 300 main and 95 needle middle notch, and a 55 pilot with pump. I have heard that the only way to tune right is to use a EGT sensor, where do you buy one for a DS? Could I be runing the bowl dry, where can I get a high volume low pressure fuel pump and how do you install them?
you can use any egt guage out of summit. as far as the probe you need to order one from a place like dennis kirk. the probes for the sleds are smaller than the ones for auto use. if you do order one for a sled l would suggest getting the more expensive fast reacting ones. no need to wait for them to warm up. i have pics of my setup posted
Russell karting has a awesome kit made by digatron and it has many more functions too speedo warning lights all programable i run this unit on my big bike it works like a charm[img]i/expressions/face-icon-small-wink.gif[/img]
Jeff Roper
Feb 1, 2022 11:48 AM
jrooker6
Apr 23, 2016 07:36 PM
