Upgrade from RW to Vortex anyone?
I switched over when I put my big bore kit in and had it dynoed. The traction map does make more torque at lower RPM range. On my bike and the dyno it was about 4 FT pounds greater. If you order for russel carting they will program what ever rev limit you want. The traction map does make take offs much better and a noticable change.
Originally posted by: MudStud
Thats kinda low [img]i/expressions/face-icon-small-sad.gif[/img]
Is there a chart I can see that showes the maps and rpm limits?? Can you scan it and post it?
#15
#16
#17
If you dynoed it, you'll find there's no real good power advantage of revving up above 9000 rpm (in most cases) rather than just shifting to the next gear. If you are topping out, consider a 15 tooth sprocket instead of a 14. If then you are worried about loss of torque in the low end, you shouldn't be - not with those A1 A2 cams. Besides, you can give your quad monster torque on the low end with the Vortex.
