Upgrade from RW to Vortex anyone?
Old 12-13-2003, 07:02 PM
MudStud's Avatar
Default Upgrade from RW to Vortex anyone?
Other then Ironrod [img]i/expressions/face-icon-small-smile.gif[/img] who has made the switch?
I am considering it but I want to make sure its worthy upgrade.
What did you see in performance in all ranges?
How do you like the maps?
Hmm, whats a used RW-CDI go for [img]i/expressions/face-icon-small-blush.gif[/img]
Old 12-13-2003, 07:21 PM
BigWaynester's Avatar
I want to make the switch soon also.. ??
Old 12-13-2003, 08:08 PM
Jerfinds's Avatar
I just posted a similar topic, Check out graydon or vortex CDI.
Old 12-13-2003, 08:28 PM
ironrod's Avatar
I can tell you there are LOTS out there. Hopefully someone else will chime in.
Old 12-14-2003, 12:35 PM
[img]i/expressions/face-icon-small-blush.gif[/img] sorry, I didn't look...thanks
Old 12-14-2003, 01:10 PM
BillDS650's Avatar
I have switch and I like it [img]i/expressions/face-icon-small-happy.gif[/img] with the Vortex I have cut down on the wheel spin on take offs. Then in tight slow section of dune rides the traction map make for easer traveling. I would like to raise some of the RMP rev limits.
Old 12-14-2003, 02:23 PM
MudStud's Avatar
Does the traction map procude less power on the low to reduce spin?
Old 12-14-2003, 04:16 PM
ironrod's Avatar
Huh? [img]i/expressions/face-icon-small-confused.gif[/img]
The Traction map is called traction because the CDI box came from the MX world. In that world, the problem with two wheelers was the huge power band that would come on with performance CDI's at higher RPMs. Therefore, the 'Traction Maps' are simply ignition maps that have the power come on in the low RPM range. This increases torque, decreases the need to REV high to get power, and therefore decreases wheel spin; This works well with quads as well. The beauty with the Vortex, is that you can switch on the fly from a traction curve (low RPM power) to a performance curve (high RPM power). In the quad world, the traction map is used for trail riding or anytime you need more torque in the low RPM range.
Old 12-17-2003, 02:16 AM
MudStud's Avatar
Let me ask this..
How much will I notice this as a trail rider?? How many trail riders have this??
Old 12-17-2003, 10:51 AM
MudStud's Avatar
Is there a set it and forget it mode for the vortex so if you dont want to always be swtiching you can run it like the ronwoods?
Quick Reply: Upgrade from RW to Vortex anyone?
