dual 39mm keihin carbs
Old Dec 19, 2003 | 10:54 PM
outlaw105's Avatar
Default dual 39mm keihin carbs
if you have them ,do you like them, will they work with the factory cable and thumb throttle. also anyone seen dyno #s on a stage3 ,going from a single carb to this dual setup.........
Old Dec 19, 2003 | 11:35 PM
BajaIowa's Avatar
Depending on your single carb, you may want to just stay with a single. Most of the guys here just run singles. You may want to read the thread farther down the page titled I got a bigger hammer. Jim has one fast DS and he is running the Lectron hv46.
Justin
Old Dec 19, 2003 | 11:47 PM
ironrod's Avatar
Unless you are big bore or oversize valves - not needed.
Old Dec 20, 2003 | 12:08 AM
PUSHINTHELIMIT's Avatar
nvm my post.
Old Dec 20, 2003 | 12:24 AM
DuneMe's Avatar
I run the Twin FCR 39's with the stock thumb throttle and cable. Needed a tricky dicky thingy dingy that Gary at TVI has for about $10 but, it works great.
I didn't cut any springs or anything and it isn't any harder than the TM45 on the thumb!
I did everything at once so, not sure what the 39's by themselves did. I like the set-up though.
You will have to cut your frame at the upper crossmember. We ended up cutting mine out. I no longer have an upper motor mount!
I have the center pull design (I hear it gives more pipe clearance so, wanted that! On dunes has them on their web site.
Know anyone that is looking for a TM45? [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 20, 2003 | 12:55 PM
Eaglecollector's Avatar
I went from the 45 to the 39's just recently. The The 39's throttle response is killer and you can not keep the front on the ground as you roll through the throttle in 3rd with stock gearing. Unless the gas cap is a butt plug. I use the twist and am also one of those that prefer the twist. To many years as a two wheeler I guess. Believe it or not..on the top end I gained nothing over the 45 in fact I lost a little. I have been able to tune the carb in some and gain back most of the top end. I feel there is still some there and will be trying diff needles. All I can tell you is from what i've seen so far [img]i/expressions/face-icon-small-sad.gif[/img] It's a hell of a lot of money to not get the results I was hopeing for.
Old Dec 20, 2003 | 06:10 PM
ironrod's Avatar
Eagle,
Do you have the larger valves in your head?
Marky
Old Dec 21, 2003 | 01:25 PM
Marky...yes I do[img]i/expressions/face-icon-small-happy.gif[/img] But I only have the web cam 110's. So that could be part of it. Im going to get the neddle that is used in the YZ 450F and give that a try. it's #NCVQ.
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
