What compresson?
Old Dec 26, 2003 | 10:05 PM
Jerfinds's Avatar
Default What compresson?
What PSI compression should I get with the RWR A1/A2 cams and 11.5:1 piston. Can you do a leak down test with a standard compression tester, the place I bought the tester did not have a leak down tester.
Old Dec 26, 2003 | 10:30 PM
Ward660R's Avatar
I was wonderring the same thing about the leak down tester. Mine has a valve in the end of it (like what is in a tire valve stem), if you take this out I think it would allow me to do a leak down test....maybe.
but TTT
Old Dec 26, 2003 | 11:06 PM
outlaw105's Avatar
sounds like you bothhave a cranking compression tester.. a leak down tester has a percentage gauge with an adjustment **** on it....
Old Dec 27, 2003 | 12:20 AM
ScoobyDFW's Avatar
maybe around 229psi, assuming static compression ratio = 11.5, leakdown = 2%, lobe center around 105 degrees, advance around 1 degree, barometer reading 29.9"Hg
Old Dec 27, 2003 | 01:43 PM
PUSHINTHELIMIT's Avatar
You can definatly tell scooby is no dummy.... LOL.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 27, 2003 | 07:00 PM
Jerfinds's Avatar
I just did a test without disabling the decompressor and got a reading of 195, cold. Is this ok, has anyone done the test without disabling the decompressor, what did you get? Should I do another test with the decompressor disabled or do you think this is within spec.
Old Dec 27, 2003 | 07:22 PM
ScoobyDFW's Avatar
i just use a small thin piece of cardboard such as a spark plug box lid, roll it up and insert into the cam to keep decompressor disabled.
Old Dec 27, 2003 | 07:51 PM
Jerfinds's Avatar
Thanks Scooby, I will try that and see what I get, I also am trying to find a leak down tester to do that too.
dodgefate
May 17, 2006 10:58 AM
DriverDoyle
Nov 30, 2005 08:35 PM
DAVEY300
Jun 16, 2005 05:29 PM
JRM
Sep 16, 1999 01:11 AM
