place to get used sand tires? also question on HUB adaptors
Old Jan 24, 2004 | 09:40 PM
R00ST's Avatar
Default place to get used sand tires? also question on HUB adaptors
alright, this is good info
another point of me being off topic....approx what is the HP gain on the 46hv?
i thought the carbs were more than 500ish... i know people rave about them so it must be excellent power for the money...
Old Jan 24, 2004 | 09:49 PM
BlackHawk's Avatar
The carbureitr is $550, then you'll have to buy a calbe, and perhaps a modified thumb throttle or aftermarket one. The carburetor produces about 8 HP more and 6 more ft lbs of torque. However, if you look at the dyno run you'll see something very nice - the HP & Torque curve is similar to the compairson, however the entire curve is just a lot higher! so it really improves power everywhere! I rode MRDS650's DS with the LEctron (he has nearly the same mods I do- except that he has the Lectron) and that thing was amazing!
here is a link to the dyno chart for it:
http://home.swbell.net/tharthun/home...ondynoruns.htm
The dyno runs are actually on Buttfungus' website. If you've got an extra $550, it's seriously worth it!
Old Jan 24, 2004 | 11:24 PM
CountryJoeGlass's Avatar
The power curve is amazing, at no time above idle does it dip down in HP. Because it has a great & even power band you forget how good it is, until you get back on a stock carb DS. I would recommend a lectron 46hv, ported aluminum carb intake & billet end cap over a stage one for the money IMO. It will out run a stage one & maybe more IMO. So if you look at it that way then the money for the carb isn't a issue IMO.
Ean
Dec 19, 2022 08:48 AM
Nondem
Feb 22, 2020 12:20 PM
toonces
Oct 16, 2019 12:11 PM
1966F100
Jul 12, 2015 03:08 AM
tporath
Jul 11, 2015 12:31 PM
