snowmoblie carbs
snowmoblie carbs
I was wondering if I could use a carb off a sled on my ds. The pilot screw is bugger in the stock carb. I can get them used for a desent price if they will work. What size and type should I look for. I can not afford a lectron so I hope I can use one of these. I can get vm44, 40. tm40 and others.
snowmoblie carbs
These snowmobiles are 2 stroke right? If they are I dont think you can tune those carbs for 4-strokes(atleast not on gas), cause 2-strokes carbs have a "power jet" that dumps almost twice the amount of fuel. It may be possible to tune it for your DS using Alky. cause running RICH on alky doesnt hurt performance that much at all. Plus you can always lean it down with alittle NITRO!![img]i/expressions/face-icon-small-happy.gif[/img]
Bigger.
Bigger.
snowmoblie carbs
I hear awful things about Lectron. The engraved number on the jets wears off quickly and you have no way of knowing what kind of jet is in the carb. Personally, I would stay away. I don't think it's worth the extra money when Keihen and Mikunis are so much cheaper.
(Just relaying info.)
