1st/ 2nd gear starts...which is faster?
Old Feb 3, 2004 | 10:59 PM
cain73's Avatar
Default 1st/ 2nd gear starts...which is faster?
A question along similair lines.......... when gearing down to use second to start in, do you change the front or the rear? I have gotten conflicting information about how to get the most from my now stock DS. Any help please.
Old Feb 4, 2004 | 12:36 AM
BigDaddy331's Avatar
Changing the front is SUPER SIMPLE! You can go to a 14 without going to a different chain. Changing the rear is a little more work but can be done faily easily.
Old Feb 4, 2004 | 01:08 AM
DaSandBomb's Avatar
I'll vote with the Majority on this when on sand, 14 tooth front ($15), add a set RW 60% clutch spring ($25), use 22" extremes. Start Second and hang on.....
Old Feb 4, 2004 | 10:06 AM
SANDMAN430's Avatar
you can go 42 on the rear with aa 15 front, use the stock chain and save a pound of weight, plus it is rotating mass. this combo works nice. but the 42 rear sprocket wont last as long as a steel stock one.
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
