Info on Magura Hyd clutch........
Old Feb 25, 2004 | 03:27 PM
  #21
ScoobyDFW's Avatar
Default Info on Magura Hyd clutch........
magurausa@magurausa.com
Magura USA
1902 Miller Drive
Olney, IL 62450
800.448.3876 - p
Old Feb 24, 2025 | 08:22 AM
  #22
sevenduce's Avatar
Smile
Originally Posted by AlkyBurninX
A local dealer and friend of mine bought a bunch of returned parts from a wholesaler. Among these were quite a few Magura clutch kits for different bikes. Well I bought 2 of them CHEAP ($25 a piece) one was for a KX125 the other for a CR250. I rigged one up on my banshee and the difference was spectacular. I run YZ490 clutch springs which are stiff. I ended up taking it off because my aftermarket carbs hung down too low and the left side would fit in the boot right.
My main reason for replying is to tell you that the reason these were returned was the original purchaser pumped the lever before installing it and I had to rebleed the system. That was a PITA!
which one did you use the kx or the cr becuse I have a magura clutch for a Banshee that I'm going to try to put on a CR250 mine also needs to be bled in that bolt is expensive
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
greg86hd
Sep 16, 2015 12:32 AM
