barnett clutch kit from alba--- any good?
Old 02-13-2004, 12:08 AM
saint650's Avatar
Default barnett clutch kit from alba--- any good?
i need a new clutch set, is the barnett set any good? is there a better clutch set out there
Old 02-13-2004, 02:16 AM
JMAC650's Avatar
The stock clutch with ron woods 60% springs seems to be the best setup. At least that is what I found watching the forum.
Old 02-13-2004, 10:23 AM
thebigshow's Avatar
i have the barnett on mine..........it started slipping the first month i bought it.
Old 02-13-2004, 11:06 AM
ScoobyDFW's Avatar
you can't use the springs supplied with the barnett kit, too weak.
i run the a 9 disc barnett setup with stock steels (sanded) at over 100HP, but with very stiff springs.
Old 02-13-2004, 03:43 PM
biggerisbetter's Avatar
I have run the Barnett clutch for over a year with NO slippage. I also use the springs they supplied. Although, For the Money it is worth getting the RW 60% springs.
I run Valvoline VR1 50w OIl.
bigger.
Old 02-13-2004, 07:34 PM
couchonwheels's Avatar
Just wondering if any of you guys have tried staggering the clutch springs with a stiffer one every other spring? That's what we used to do to the old 3 wheeler 250r's to keep a strong clutch, but not Popeye your forearm on rides. Curious if same concept applies to the DS?
Old 02-13-2004, 09:32 PM
CountryJoeGlass's Avatar
As couchonwheels replied, I have buddy that does that on drag banshees. Will it work on the DS650?
Old 02-13-2004, 09:59 PM
dunesled's Avatar
I have had the Barnett for a year and a half with supplied springs and have had no slippage!
Old 02-14-2004, 02:14 AM
saint650's Avatar
so what if i ran the barnett clutch with ron woods springs?
Old 02-14-2004, 05:00 PM
222's Avatar
222
222 is offline
start doing hand and finger exercises now!
222
Quick Reply: barnett clutch kit from alba--- any good?
