100/90 Blue Xenon bulb strain electrical system?
Old Feb 25, 2004 | 04:56 PM
NLWarrior01's Avatar
Default 100/90 Blue Xenon bulb strain electrical system?
Originally posted by: Slowride
I just picked up bulbs for my two auxs at an auto parts store and they were 55watt replacements *and* a direct match on the part numbers....Not sure whats going on there.
Basically, you are taking a 50w bulb out and adding a 100. You are really only adding 50 watts to the stock system.
Were did you get the xenon from?
jbt
It may be only 50W, but at 12V that's a fairly good chunk of current. Over 4A. It may not be a problem, but then again .. I'm not sure what the load is on the baja X stator either. Shouldn't be too great.
Old Feb 25, 2004 | 07:37 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
If you really want to shed some light on this situation and save weight, check this out---www.lightforceusa.com/rmdl240.html
240 Blitz
100-watt Xenophot Bulb/1,000,000 candlepower
9.5-inch Diameter
Focus from a Pencil Beam to a Spot
Shatterproof Construction
Lightweight - Only 32 Ounces
Easy Installation
Double the Versatility with Filters
I have bulbs that draw 35-50-75watts... I also found a way to mount these particualr lights... I payed $300 to have these types of lights welded and mounted w/bracket and wireing install (what a waste)... I eventually took bumper off completely, re-drilles out the holes in frame just a bit more and WALLA!!! save 6-7 lbs and can see REAL good..
Old Feb 25, 2004 | 09:28 PM
01ds650's Avatar
Let me know what you guys find out.
I put 80/100 Xnons in my wifes Grand Cherokee & also changed the wiring harness to the headlights for the extra draw. The bigger guage wire adds power too. The headlights look like HID's. Not blue, pure white with the harness.
Wonder how a Sylvania Silverstar would do in the DS?
Old Feb 25, 2004 | 09:38 PM
lilnotts's Avatar
240 Blitz
9.5-inch Diameter
Easy Installation
holy ****!!!! [img]i/expressions/face-icon-small-shocked.gif[/img], those are quite the lights u have there, prolly work great for wat u do but i could see me sliding into a tree wen its wet and smashing those off
Old Feb 26, 2004 | 12:18 AM
  #15
Slowride's Avatar
I try to gauge my concern on wattage, not amps. If I were to convert the 12vdc power to 115vac and run the bulb at .45amp , it would still be the same load on the wire, connectors and stator, but for some reason it just doesn't sound near as bad. Convert it to 5vdc and the 10Amps, and it starts to sound scary....its all still 50watts.
The extra charging system capacity of the Baja was a definite selling point for me, but I don't think I would add a cigarette lighter just to see if it would support it.
But to keep it in perspective, if we were talking about adding a 50 watt load to my Raptor, I would throw a meter on a few connections to check some current draws before plugging the item in.
I knew I could twist this into another key feature comparison for something the Bomb has that the Raptor don't.[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Hillbilly, thanks for screwing up my world. I spent 45 minutes reading bulb lables today trying to find the 135w highbeam on a 60w draw. Pep Boys had a 60/55 but it was comparable to 100/90. Now I got to find a place with the PIAA bulbs in stock....
ANNIHILATER, you're out of control. If I ran up the hill as fast as you do at night, I would have 10M candlepower lighting my path.
jbt
Old Feb 27, 2004 | 01:08 AM
  #16
natron1's Avatar
Just got my first inside track mag from Harbor Freight. #219 In it are three Xenon bulbs----- 60/55 watt h4 2for $7.97-----80 watt 9006 2 for $9.97------65/55 watt 9007 2 for $9.97. Its my understanding that once you pay 10 dollars to join the inside track club you can access it on the internet. At these prices it might be worth it to join. I'm gonna get them and try them in those baseball size fog lights. That are also in the same mag for $13.97. Pep boys and other part stores want as much as $40.00 for.
Old Mar 3, 2004 | 05:20 PM
  #17
lilnotts's Avatar
Originally posted by: lilnotts
Originally posted by: BartlettRacing
oohhhhhh they make a ultra show yellow h4 100/90 for my baja x that would look trick [img]i/expressions/face-icon-small-smile.gif[/img] anyone know what the lower lights take for bulbs?
ya might wanna look at ur headlight, i'm pretty sure they're not H4,
i'm glad to see everyone pays attention to my posts
Old Mar 4, 2004 | 12:18 AM
  #18
BlackHawk's Avatar
Hey - I was right about the lower ones being H3s! So what model bulb are the 2004s using in the main headlight?
Old Mar 4, 2004 | 12:33 AM
  #19
Slowride's Avatar
Just tested my new H4 (60/55 = 100/90). I can see for miles and miles, or about a 1/4 mile, which ever comes first. Basically lit up a hill that is a "measured" 1/4 mile away. Pretty impressive beam and with the 55w lower lights, the path looked well lit.
Got to love the Pep Boys APC bulbs, 2 for $30. Now to see if they're trail tough.
jbt
Old Mar 4, 2004 | 10:47 PM
  #20
Slowride's Avatar
Bartlett -- I saw that, you're out there. 270w of light has got to be close to insane.
I'll understand the level of insane once I get mine in the dunes next weekend. If it ain't stupid bright, I may be looking into the Bartlett type of setup.[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
jbt
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
John Reed
Sep 9, 2015 03:46 AM
Elkaholic
Sep 6, 2015 02:44 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
