Cutting Fenders!!!
Old Feb 27, 2004 | 12:56 AM
Haulinonthedunes's Avatar
Default Cutting Fenders!!!
Old Feb 27, 2004 | 12:57 AM
What did yall use to make the cut on the fenders? Thanks
Old Feb 27, 2004 | 01:12 AM
CountryJoeGlass's Avatar
I think maybe a jig saw, band saw, scroll saw or maybe a sawzall. dang my bad spelling would be cut by a chop saw[img]i/expressions/face-icon-small-disgusted.gif[/img] oh well I tried! Sorry know help here!
Old Feb 27, 2004 | 01:17 AM
dunesled's Avatar
Tape off your lines using electrical or duct tape then jig saw with a fine fine tooth blade. Piece a cake!
Old Feb 27, 2004 | 01:19 AM
well said!
buttfungus's Avatar
I did the same as dunesled but I used a dremel and cutting wheel.
Old Feb 27, 2004 | 02:08 AM
DuneMe's Avatar
I used masking tape and then a sharpie on the tape to mark off where I was going to cut. I used a small 9.6volt cordless Makita sawzall with a metal cutting blade (small teeth.)
Once I finished cutting I pulled the tape off and used a sand pad (about 8") on my air grinder. Hold it flat as possible and it will clean up the lines - make them straight.
Also, the tape keeps the fence of the saw from scratching up the plastic.
Did mine a few months ago and my buddy's this last weekend!
After you do it you'll have to get some Roll Design Foot Pegs [img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 27, 2004 | 02:29 AM
jiminok's Avatar
Nobody said, "chainsaw"...er uh never mind.
Definately use masking tape and get your lines drawn out...
Mmmmhmm...roll design footpegs too!
Old Feb 27, 2004 | 02:30 AM
BROWN650's Avatar
we cut mine tonight and it looks good thanks to quadman and his dad!
Old Feb 27, 2004 | 09:45 AM
MrMeaner's Avatar
Making tape, Dremel and when done use fine sandpaper and a block of wood. It make it straight.
