torque numbers
Old Mar 19, 2004 | 06:58 PM
okds650's Avatar
Default torque numbers
is there a sight where I can get torque numbers fo putting my motor back together?
Old Mar 19, 2004 | 07:31 PM
SANDMAN430's Avatar
just ask here there not that many anything that is a small bolt is a 89 inch pound the head bolts are 44 ft.pounds the smaller ones seems there 24 ft.pounds. the cam chain tensioner is 30 something i'm sure others will fill in the blanks.
Old Mar 19, 2004 | 08:32 PM
okds650's Avatar
head bolts were my main concern thanks
Old Mar 20, 2004 | 10:20 AM
SANDMAN430's Avatar
got my shop manual back so if you need any other let me know.
Old Mar 20, 2004 | 12:12 PM
BlackHawk's Avatar
I'm quite sure people have said do NOT tighten the head bolts to 44 ft lbs, I think it was 222 or Mr. HP that recomended 39 ft lbs. I have heard of people shearing bolts off, just trying to achieve 44 ft lbs. You might check by doing a search and see what you find.
Old Mar 20, 2004 | 03:31 PM
SANDMAN430's Avatar
well, i've done mine to that torque, and i'm sure bombardier knew what they were doing, when they went for that number. but ihave also had to replace head nuts from going to that torque. i now run the stronger stay bolts.
ReconBayou
Oct 16, 2019 02:24 AM
Johnny Mac
Aug 15, 2019 03:13 PM
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
