RWR piston rings... Gapless or gap??ASAP!
Old Mar 31, 2004 | 11:24 PM
Majorecho's Avatar
Default RWR piston rings... Gapless or gap??ASAP!
DSaholic and I are putting his motor back together as I type and I was getting ready to file fit his rings and wanted to check the fit of the original RWR rings on his hicomp piston, there is no gap on the original rings??? This piston was bought used from another forum member so we don't have instructions on ring installation, I need some input ASAP on wither or not these rings need to be gapped or not- I've heard of gapless rings but never used any - does anyone know if these are gapless??
thanks
Old Mar 31, 2004 | 11:48 PM
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Gapless rings MUST be file fitted. Call Ron Wood for specs.
Old Mar 31, 2004 | 11:49 PM
Majorecho's Avatar
wow someone answered the phone @RWR 3+hrs after closing[img]i/expressions/face-icon-small-shocked.gif[/img] and yes they are supposed to be gapped! Back to the garage we go!
Old Mar 31, 2004 | 11:57 PM
BIGBAJA's Avatar
.016-.018 Gap should do it
Old Apr 1, 2004 | 01:25 AM
Majorecho's Avatar
thanks for the replies!
Old Apr 1, 2004 | 07:14 PM
DSaholic's Avatar
Hey thanks for the replys guys.
We got the piston in just fine with a .017 gap per ron woods. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 3, 2004 | 11:31 AM
222's Avatar
222
Hold on! .017 is tight even if you were running standard rings. This is way tight on gapless rings. Are you running gapless top rings or gapless 2nd rings? I suspect you are running the gapless top rings (because several years ago, I spent countless hours on the phone and shipping ringsets back and forth with the mfg to get it right for a ds650 - and yes, it is annoying that others get to benefit for hours and $shipping, but that's part of the business). The gapless top rings should be .022 MINIMUM.
You wouldn't believe how many motors come in for repair that gave up the ghost long before they should have, and the reason for the failure was improper ring gap! And I'm talking about "professional" engine builders.
222
Old Apr 3, 2004 | 12:47 PM
Majorecho's Avatar
this is a RWR piston and ring set, they told me to set them up @ .017" so we did.
Old Apr 3, 2004 | 02:19 PM
222's Avatar
222
Unless RW is manufacturing rings, they are Total Seal ringsets. But, you are correct, you should trust the source of your parts for technical info. Sorry if I confused things.
222
Old Apr 3, 2004 | 08:30 PM
Majorecho's Avatar
all the same, thanks for keeping an eye on us.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
slowgsxr97
Sep 8, 2015 07:33 PM
