bogging..
Old Apr 5, 2004 | 11:10 PM
javex's Avatar
Default bogging..
when the bogging starts, i'm getting up there in rpms. what rpm it starts at i don't know cause i don't have a tach. it is sudden, it just sort of shuts the engine down until i release the throttle some. but it seems like the engine should rev out more, u know? i guess it must be the rev limiter. don't know what else is causing it. until i hit it, there definetly is more power. i can hit it at about 3/4 throttle in any gear.
Old Apr 5, 2004 | 11:51 PM
JMAC650's Avatar
Default bogging..
If you are in the higher rpms and it does it in every gear than it sound like you are hitting the limiter. Is it like a instant sputtering? If it is thats the limiter. try 5th gear and open it up and see if you can hit the limiter. I know it is hard to hit the limiter in 5th gear unless you have a long stretch of wide open space.
TeamYZF
Jan 13, 2008 11:42 AM
pinheadedjoker
Aug 26, 2004 10:20 AM
