stock chain plus 14t sprocket
I was needing the answer to this question too... I tried to install my 14t sprocket, but couldn't get the chain tight. I thought it was because of my skid plate.
I guess I'm going to need two chains instead of just one. Do the Rocky Mountain master links still use o-rings, or are they just standard 530 master links?
I can run anything from 14 to 17 with no change in chain length.
the new models with the shorter swingarm may be different?
If you put a 14 on, you need to turn around the rear engine mount bolt - put the head on the right side and the nut on the left or the chain will rub the bolt that sticks out through the nut
