DS Vibration????????
Hi i just got back from riding and i have noticed that if i run along the beach at just over half throttle in top gear there is a fair amount of vibration through the foot pegs enough to be annoying. the bike is new still breaking in hence the half throttle thing
There is nothing through the bars and if the revs go higher or lower it goes away
I know some motors have a critical speed type balance problem at certain rpm i just wanted to check if this is norman for a DS[img]i/expressions/face-icon-small-confused.gif[/img]
Thanks man i thought it was probably just the way they were but you put my mind at rest. When the 250r vibrated it usualy meant the balancer shaft bearings were on ther way out[img]i/expressions/face-icon-small-smile.gif[/img]
I've noticed with the Wife's Raptor the vibration is in the bars but, with the DS it is in the pegs.
Ride fast and you won't notice [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Thanks i will sleep easy now
I will try and get another couple of hours in tommorow if the weather holds then its oil change time and i can start to use it to its full potential, hopfully my end cap will arive before i leave for work friday so i can try it out to if not i will have somthing to play with when i get home in a few weeks
Ive noticed that my 770 pegged in 5th makes my teeth rattle [img]i/expressions/face-icon-small-happy.gif[/img]j/k
