Let's talk CDI's
Old 04-23-2004, 01:12 PM
sam's Avatar
sam
sam is offline
Default Let's talk CDI's
I love my RWR CDI I have misted shifts to and she still runs like a top. IMO I would not worry about over reving( with in reason) unless you flip it and the throttle sticks, but if we all were worried about that we would have tethers. any way Im glad the spectrom of CDI are getting wider. For god sakes we only had2-3 options at a high $$$ now they range from $99 to $500.[img]i/expressions/face-icon-small-happy.gif[/img]
Old 04-23-2004, 01:52 PM
OregonDunePatrol's Avatar
Originally posted by: JEFFROE
have had the rwr and graydon. didn't see any difference between the two? but wow! the vortex really woke things up[img]i/expressions/face-icon-small-happy.gif[/img] it does have a lower rev limit at 8800rpm but my ds isn't making alot more after 9000rpm anyway (plus if and when i miss shift it catches me) plus switching on the fly to a retarded setting for hole shots works great.
While the DS stock motor is hard to overrev, I can tell you that the stock piston will come in contact with the stock valves at 8500 RPM. That can cause a number of problems down the road. This includes weak and eventual bent valves. As soon as you start adding motor mods (ie Piston, cams, and valves springs) the potential of the motor to overrev goes up considerably. Valve float happens at 10,000 RPM in a typical stage II motor. If you float the valves, spring damage will occur. The result will be valve spring failure and bent valves, or the shims leaving thier buckets and being chewed up by the cams (I know, I've done this!). There's not much good power past 8500 RPM anyways. In most cases, it would simply be better to shift to the next gear. I think if you look at the multitude of dyno tests out there, you'll see a power drop at or around 8500 RPM.
Old 04-23-2004, 03:17 PM
JEFFROE's Avatar
when i took apart my stage III 650 motor for the 760 kit there was 2 smiley faces on the top the rwr piston!! it still ran ok but when they start to meet it can't be good on parts[img]i/expressions/face-icon-small-wink.gif[/img]
Old 04-23-2004, 04:56 PM
JEFFROE's Avatar
i can remember ice racing and having it pinned in 3rd and 4th ( at the time no tach ) and just twisting the poor thing for a long time again and again as far as it would go, without any rev limiter. tough suckers those rotax's.
  #15
Old 04-23-2004, 07:06 PM
SANDMAN430's Avatar
when i took apart one ds for piston and cams no smiles, took apart the one the wife rode two smiles.
  #16
Old 04-23-2004, 07:15 PM
VEGAS650's Avatar
If you are going to use one with no limiter, make sure you check your screen in the oil tank rgularly.
If you over rev and don't have proper oil flow, your engine will look like mine did![img]i/expressions/face-icon-small-sad.gif[/img]
You can get the MSD from TVI, for $400, that's not much more than Woods.
Sandbomber, send yours back. They just sent me a new one cause mine was only producing spark from one plug wire.
Al
  #17
Old 04-23-2004, 08:25 PM
sandbomber's Avatar
Im sending mine back after goldendale race this weekend. It rev up to 7500 & with the 770 thats enough[img]i/expressions/face-icon-small-happy.gif[/img]
  #18
Old 04-26-2004, 12:59 AM
zillanator's Avatar
Thanx for all the input. I'm leaning towards the Vortex at this point. Any other input that you guys have to offer is mucho appecienado. Gratis[img]i/expressions/face-icon-small-smile.gif[/img]
bigred20653
10-02-2015 10:05 AM
mbriggs
09-13-2015 10:47 AM
awer1968
09-08-2015 11:02 AM
MikeyBoyesq
09-07-2015 10:44 PM
Technical and How-To Articles
08-21-2015 09:31 AM
Quick Reply: Let's talk CDI's
