Awesome webpage....figure out top speed of any gear
I thought all of you would be very interested in this webpage.
This guy has created a web based program that will aid you in figuring out top speed of any gear.
http://www.t5net.com/common/faq/Form...rsplitter.html
Try this gear ratio calculator: nightrider.com/biketech/calc_gearratios.htm. I'm estimating that the engine sprocket is 30 teeth and the clutch sprocket is 64 teeth, but I could be totally wrong on this. Transmission sprocket is 16 and rear wheel sprocket is 40. I don't know the individual gear ratios.
Guest
Posts: n/a
That one looks like it may work pretty well Scooby, has all the major bases covered. With accurate input values I think it would give pretty accurate results.
I need to figure out what the gear ratios are on the DS650. It has a constant mesh transmission. I have a parts catalog that shows all the gears and the number of teeth, but I can't figure out the gear ratios and primary reduction. How do I calculate this?
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
