Ball Joint Removal.....need advice
#21
#22
Another thought I had was to remove the old ones, buy some that are a hair bigger and have the knuckle machined at a shop to fit them. I have seen ball joints for trucks for $12- $15. If they work on trucks I'm guessing they would be sturdy enough for the Bomb. Anyone with machining experience have any feedback on that? That way I could afford to replace them all and woul dnot have this problem in the future.
#23
Come on ! somebody must have had this problem before us. Has anyone found a different brand that will fit to replace the moog one? or has anyone been able to cross reference the bombardier part number 703500082 to find an automotive one to check prices with? There has to be one since they use them in cars and trucks.
#24
#25
#26
a friend of mine with a raptor did change to a different ball joint. the differnce ended up in the tapered shaft. it had a slightly different taper. he just carefully dremelled the taper to fit. insted of cross referencing the part #. they just crossed to a very close dimention. not sure if napa can cross dimentions on that part or not. but, they have for me on other parts.
#27
jrooker6
04-23-2016 07:36 PM
