Question for THEBOMB??
#31
bigger you are correct it should go by % instead of hp rating because it takes alot on dyno time to get a 20hp shot to build 20hp on a 15.1 motor but it can happen with alot of tuning but a 100 shot =75-80hp increase on the rear tires most casses my nx system may build a extra 10 or so what do ya think??????????????[img]i/expressions/face-icon-small-wink.gif[/img]
#32
I'm not sure what you ended the day on last time, but I know I was no match no more, and I also noticed that all the 'drag banshee'" guys CONVENIENTLY parked their quads . LMAO.
good luck to ALL you crazy som-bitches!!! Just dont blow up while you passing ME. LOL.
BIgger.
BIgger.
#33
Originally posted by: shanebv2
15 !!!!! no wonder you were beating my poor little air cooler
Lets see I had 12 to 1 in my little honda so 15 - 12 is 3 you were beating me by 3 bikes now I have 14.5:1 so 15 - 14.5 is .5 add one for my good looks and style 1 - .5 is .5 so now I will beat you by .5 bikes !!!!
anyway I got the turboQuad moving again under it's own power I should be able to dial in in a bit at orgeon on the 12 and 16 so it should be ready to put it's best foot forward when we can go to dumont again in oct ......
Shane
Shane
Bigger and Stacy I have not heard of that yet but you may be right, Either way I feel a great gain just off 22-26 jets... I will be dynoing it soon and we will find out.. I want to get everything right first (just about there) The I will do a baseline motor run first and go from there on the nos jetting to see what gives... Seat of the pants gains feel great, But I wont believe a thing till I dyno it myself, then I will tell and show you the gains and then we will know what up with it.
[img]i/expressions/face-icon-small-happy.gif[/img]
#34
thats definatley the best thing to do. Dyno each shot and keep an eye on your tempature guages, go up on your shot size till you see a lean condition starting to occur. Just make sure your bottle pressure is where you want it to be each time. Good luck man!!!
bigger.
#35
I just called holley NOS teck line and the Guy said absolutely no way do you need to run a bigger shot for higher compression... He said the higher shot you go on a high comp motor means it would be more prone to detonation you need to go w/ higher octane when going bigger on the nos increase. He also said that on a built motor IE ported etc., you need to run a bigger shot due to how much more the motor is breathing.
#36
#37
You might not "need" to run a bigger shot for a higher compression motor, but I think what bigger was saying is true. Looking at it based on a percentage gain per amount sprayed in a higher compression motor will make less power. I believe it has to do with the flame speed.
Say you sprayed a 20 shot on a 10/1 motor, you'll gain about 20 hp.
If you used the same jets in a 15/1 motor you may only be gaining 12 hp.
Disclaimer: I really know nothing, but that is the way I understand it.[img]i/expressions/face-icon-small-wink.gif[/img]
My question is; does anybody (Bigger, SamCoeDS, THEBOM, ect) know if this is true on a nitro motor as well??? Or anybody know who I can find that out from?
TIA
TIA
#38
#39
i dont run nothing nos sells or makes i run nx brand only nx plant with dyno is 46 miles from my house mike wood (the owner of nx)is a very good friend of mine and has sponsored me for many years in all types of racing so i know nitrous and its fire paths and flame rate with diff weight fuels including nitro so some guro i dont know or have ever seen race anything is going to tell me anything about how nitrous builds power this ant my first nitrous rodeo.[img]i/expressions/face-icon-small-wink.gif[/img]
#40
