USFS run in
Old Jul 21, 2004 | 07:08 AM
  #21
01ds650's Avatar
Default USFS run in
HMF sends a heat proof sticker for the spark arrester. It's OK, but I got a set of punches that have the alphabet on them. I just punched USFS APPROVED on the rim of the spark arrester. It looks legit to me. Gotta hammer down hard though[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 21, 2004 | 10:20 AM
  #22
BajaXRider04's Avatar
Default USFS run in
Originally posted by: couchonwheels
Running the screen sounds fine until you run up to a Ranger that wants to see the USFS Approved stamped on your pipe. Most Rangers around here are cool, as long as you have a arrestor, but I have had a couple that want to see it stamped in the pipe also.
The original DS pip does have the USFS Approved Stamp, and you dont loose this stamp just by putting on an endcap [img]i/expressions/face-icon-small-wink.gif[/img]. If you have a screen of some kind in the exaust you should be good as long as they dont check the sound levels of the end cap?
Old Jul 21, 2004 | 12:54 PM
  #23
DSengineer's Avatar
Has been here a long time!
Default USFS run in
Originally posted by: BlackHawk
I really like the ability to switch back to 'stealth mode' any time I need to in five minutes for both quads.
What about jetting? Switching back to the stock endcap you are going to be running really fat.
Old Jul 21, 2004 | 01:11 PM
  #24
Hez's Avatar
Hez
Default USFS run in
DSengineer:
thats true because when i had the stock endcap on and i was running around at 5500' my DS would hesitate a bit. (stock jetting) but as soon as i put the Mr.Hp endcap on it ran much much better
Old Jul 21, 2004 | 01:12 PM
  #25
BlackHawk's Avatar
Default USFS run in
On my DS with the Lectron it shouldn't be too bad, and the DS with the stock carburetor can be re-jetted in five minutes if it becomes a problem, however my 2001 (with the stock carb.) isn't very picky about jetting. I figure if it bogs like hell when I make the switch I'll do something about it then. The Lectron's needle is worth many many jet sizes, so between those two factors it shouldn't be a problem. The worst case scenario is it takes me ten minutes total including time to rejet the 2001.
The area I'm most concerned about being hassled for noise / spark arrester is at my nearest riding area - Hungry Valley which is about 30 minutes away, most of the other places are really not too much of a concern unless I go to one of my old haunts or some place I've never been.
Old Jul 21, 2004 | 03:45 PM
  #26
BillDS650's Avatar
Default USFS run in
Just fit a five inch Supertrapp core and have both worlds 10 disk for USFS spark arrestor and noise then just bolt on a open end cap for close course.
Old Jul 21, 2004 | 05:37 PM
  #27
BlackHawk's Avatar
Default USFS run in
I haven't had as much luck as I would like with the Supertrapp or WB E-Series discs limiting noise. For example on my Mojave - it had a white brothers mega alloy pipe (megaphone) with the supertrapp discs. With the number of discs I bought it was ok, quite loud, but ok on power etc. When I went down to as few as one discs testing it, one discs ran like crap but still seemed to make a lot of noise.Three discs ran okay, and was quieter than six, but it certainly didn't make it 'quiet' by any means. Has anyone had a Disc system that made the machine literally 'quiet'?
Old Jul 21, 2004 | 05:44 PM
  #28
TheOz's Avatar
Default USFS run in
Originally posted by: DuneMe
It has been a while since I checked the HMF site but, when I was looking they didn't offer a USFS pipe. Worth a double check before you order your pipe.
I've e-mailed HMF and their stock DS slip-on does not have a USFS approved spark arrestor. You must purchase the QuiteCore insert. Here's the reply from HMF.
"Our spark arrestors are USFS approved and will work in the DS650 slip on. The quiet core does come with a spark arrestor."
Dan/HMF
Old Jul 21, 2004 | 05:49 PM
  #29
TheWeedman's Avatar
Default USFS run in
hey outerlimit, y the hell is your son in the picture wearing a damn coat at the dunes?????????
Old Jul 21, 2004 | 06:09 PM
  #30
01ds650's Avatar
Default USFS run in
My HMF quiet core & spark arrestor are TWO seperate pieces. They can be run together or one at a time. Perhaps they want you to purchase them together now? Ask if you can get them seperate, I did.
