15T front for 22" sand tires?
only one potential issue with 14T front - the rear engine mount bolt must be installed with the head on the right side and the nut on the left, or the chain will rub the end o fthe bolt where it protrudes thru the nut if its on the left side. And then later when it ever comes time to remove this nut, it will be a b!tch.
So with regards to the rear sprocket, would you go with Aluminum or Stainless or Chromoly?
I was going to use the 15T with 22" Sand Star's with the stock rear sprocket but after reading some of the history maybe I should switch to a 40T rear?
WAIT: The stock is 40T so do I change to 42T? OR ????????
#15
#16
#17
I rode Glamis 2 weeks ago. I day bone stock with 22 haulers, the next day with an end cap, jetted, and K&N. Day 1 I was not happy with the DS performance at all. Day 2 was 180 degrees out (better) from Day 1, I loved it! IMO the stock gearing is perfect with 22s unless you are bone stock. With a couple of relatively low-cost mods it worked awesome; 3rd gear was used almost in total, from almost dead stop turns to full-on throttle through the bowls. I really liked it.
JackTheKing
07-14-2015 09:09 PM
