bog problems
Old Dec 5, 2004 | 09:25 PM
Hittler's Avatar
Default bog problems
I took my quad out today for the first time since adding a tm45,ported intake, vorteck ignition, and also had to get those 22 inch mud machines tires everybody was talking about. The machine has a bad bog all the way up to about 7000. What should I do. I have the stock 16 tooth front gear on front but that can't make it bog as much as it is (but I did just order a 14). When I give it about 3/4 throttle off idle it spits and sputters then goes through the rpm range as a dog in all gears. help
Old Dec 5, 2004 | 09:43 PM
SpinCycle's Avatar
Guess[img]i/expressions/face-icon-small-happy.gif[/img]rop the needle 1 notch (leaner). what do the plugs look like?
Old Dec 5, 2004 | 09:52 PM
Hittler's Avatar
My plugs are wet. must be rich but whats the fix?
Old Dec 5, 2004 | 09:57 PM
SpinCycle's Avatar
just for the fact tht it is reving to 7k means that the main may not be that far off, dropping the needle will lean everything from idle to 3/4 throttle. what size main is in there now?
Old Dec 5, 2004 | 10:13 PM
Hittler's Avatar
I don't know what size is in it now. I just got it from on dunes performance last week and they set it up.
Old Dec 5, 2004 | 10:35 PM
eRo's Avatar
eRo
is the ac pump active?? make sure it is not giving a huge squirt of gas.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
