Wheel Bearings
Its probably a sticky brake calliper. to check the bearing jack the wheel of the ground hold the top and bottom of the tire and pull on it so as to tilt the wheel if you have movment you have a lose / worn bearing , if its just loose this can cause the disc to rub the pads and make a bit of noise.
hope that helps if not ask again.
I would raise the front end off the ground and have someone to hold the handelbars still and see if there is any play in that wheel.And I would make sure that the noise is not comming from the brakes,spray some WD40 on the disc and rotate the wheel see what happens.My sqweek sound was the brakes.
Cantbuytime
Aug 16, 2015 09:13 PM
