Need advice on this a-arm/swingarm/shock setup....
On my '01 DS i have Works shocks up front with stock width a-arms and stock swingarm with a stock rear shock. I am thinking of keeping the Works front shocks but adding +1 +1 a-arms and keeping the stock rear shock but getting a +2 swingarm. From all I have read and a little from first hand experience, the front Works are sprung just a tad stiff as I told them to build me a set for my correct weight and trail use. I know +2 arms might be a bit much but do y'all think since the shocks are already a little stiff and the arms I want are only +1 width that things might be ok? I only ride the DS on fire roads and I want a plush ride. I know the same principle applies to the rear as the +2 swingarm will soften the rear end but I actually want this along with a slightly lower rear ride height. Keep in mind the DS only sees casual fire road use with no airtime. Any thoughts on this setup? Many thanks in advance!
For the most part they are logging roads with ruts and all sorts of irregularities but the thing is that I am usually at 70mph+ speeds and stability is my first concern. I have no concerns of width either, just loking to stretch out the length and width to smooth things out in fifth gear riding.
jrooker6
04-23-2016 07:36 PM
