pulls right
Old Mar 14, 2005 | 09:21 PM
shimley501's Avatar
Default pulls right
I have a 2000 ds 650 and the right rear wheel is not turning as powerful as the left. can anyone help and tell me what is wrong
Old Mar 14, 2005 | 09:51 PM
tombomb's Avatar
Default pulls right
Uneven tire pressure allways makes it pull or drift. Check it out.[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 14, 2005 | 11:23 PM
shimley501's Avatar
Default pulls right
The Right Wheel wont spin at all
Old Mar 14, 2005 | 11:50 PM
JDsBusa's Avatar
Default pulls right
Check your wheel bearings, also check you caliper, sounds like it could be sticking.
Try to spread the pads apart. If they will, try to spin the wheel by hand. If it is still tight, take the wheel off the spindle and inspect the bearings.
Justin
Old Mar 15, 2005 | 01:30 AM
MongoDS's Avatar
Default pulls right
You say the right rear wont turn but the left will? Im sorry but is'nt the DS's rear axle solid?
Old Mar 15, 2005 | 05:04 AM
busmechanic's Avatar
Default pulls right
the only thing that could do that. is the splines on the axle stripped off. or the hub stripped out. are you sure thats what is happening? jack up the back and try turning the wheels individualy. if one turns and not the other. you need to take the hub off. theres no bearings in there. just splines.
the axle couldnt break inside the carrier could it?
Old Mar 15, 2005 | 09:01 AM
Prozack's Avatar
Default pulls right
Imposible..... Its all or nothing......
If the axle is broken inside the carrier , you couldnt even ride the quad!! It would be tooooo obvious !
Lets say that the axle was broken , The drive is on the right side and it would be the left side that doesnt turn ... not the right.
shimley501, are you talking about the front or the rear wheels or are you just playin with us ??[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 15, 2005 | 06:27 PM
shimley501's Avatar
Default pulls right
found the problem, it was the wheel spinning inside the tire. anyone know where i can get a cheat wheel?
Old Mar 15, 2005 | 07:07 PM
Default pulls right
obvious to you and I! I try not to asume anything. but now that I think about it. the axle would just walk out.
whats wrong with the wheel? maybe your tire needs replacing.
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
