Aluminum Rear Sprocket?
Old Mar 30, 2005 | 01:15 AM
Dingo2's Avatar
Default Aluminum Rear Sprocket?
Anyone have any idea where I can get a good aluminum rear 42T rear sprocket. I'm currently running 14/40 gearing right now with 22" Haulers for sand and was thinking about going to 15/42 with the lighter rear..gearing is nearly identical and I can then save alittle rotating mass with the aluminum rear?
Any pros or cons to running a rear aluminum?
Old Mar 30, 2005 | 01:23 AM
SANDMAN430's Avatar
woods has a 42 rear, sprocket speacilist has a better one for a few bucks more
Old Mar 30, 2005 | 01:25 AM
maddog56's Avatar
I tried running a renthal aluminum unit on my raptor, thing was chewed up after a couple of sessions of ice practice. I dont mind sacraficing for speed, but this is just not a worthy tradeoff IME. Picked up a new 42 tooth steel renthal the next day. Used that the rest of the season and it still looks great.
Old Mar 30, 2005 | 02:16 AM
busmechanic's Avatar
I ran a aluminum sprocket for one season. its toast. I will not run one again.
Old Mar 30, 2005 | 09:39 AM
OregonDunePatrol's Avatar
If you ride often, the aluminum rear will last about one riding season. More or less depending on other conditions. If your rear bearings are worn, and there is quite a bit of play in the carrier, you'll only get a 6 rides off of the aluminum sprocket.
Old Mar 30, 2005 | 12:35 PM
chirochris's Avatar
Maddog,
whats the deal with the free stuff in you post, true or what?
fill out some stuff , tell some one and i get free stuff.....come on
Old Mar 30, 2005 | 02:28 PM
TexasPsycho's Avatar
I've never ran an aluminum sprocket on my atv but I did run them on my dirt bikes. The only reason I did that was because I had a cheap place to get them. After the shop I was using closed I went back to steel sprockets because the aluminum just didn't last. You really won't save much wieght, maybe a pound? I know with aluminum sprockets it a good idea to change your chain if it shows any sign of wear or it will wear down the new sprocket fatser.
Old Mar 30, 2005 | 07:07 PM
SCOUNDREL's Avatar
If your worried about weight but want strength go with Stainless Steel or Titanium. You can get them at Sidewinders or maybe Rocky Mtn.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
