Where is the best place to order the brass swingarm bushings?
Just like the title says, I kind of messed up one of my brass swing arm bushings and need to know where the best place to get it at.
thanks in advance,
Brandon
thanks in advance,
Brandon
There are some aftermarket manufacturers out there that make pivot bearings. But I dont know if anybody that makes the press-in brass end pieces that hold the bearings in place. Your dealer would be the best choice there.
thanks, that is what I kind of thought. I did a search and found that one guy said that thare is "No brass bushing on the 04 and 05 the new swing arm uses bearings and different pivot bolt ". I wonder if these will fit in the older style ds 650's. Also it looks like all these bushings do is let the pivot bolt ride on them to keep from wearing out the swingarm and they do not hold a bearing in the front.
thanks again,
Brandon
thanks again,
Brandon
