Neutral light.
Old Apr 18, 2005 | 10:19 PM
w1ngnut's Avatar
Default Neutral light.
Hey guys. My neutral light is stay on in all gears. Do I have a bad sensor, sending unit? Any idea what the prob is? Thanks in advance....
Old Apr 18, 2005 | 10:31 PM
400EXerciser's Avatar
Unscrew the lead to the sensor, if the light is still on your wire is grounding somewhere along the way as the sensor works by grounding the circuit when in neutral. If the light goes out it is your sensor stuck in the ground position.
Old Apr 19, 2005 | 12:43 AM
2005DS650X's Avatar
Mine does that after I wash it a the car wash, once you shut the key off and turn it back on everything is fine and normal.
2005DS650X
Old Oct 21, 2007 | 11:07 PM
onastick's Avatar
i have the same problem with my outty 04. the neutral light likes to stay when the bike gets wet, (happens alot). i don't know alot about the wiring or where to look. can someone show me where they are and how to fix it.
thnx
95wolv
Sep 27, 2024 12:00 PM
Dammar
Apr 20, 2016 06:03 AM
2many2ride
Sep 27, 2015 04:35 AM
strokesb16b
2) Chassis problems..
Sep 15, 2015 09:19 PM
poutlaw525
Sep 9, 2015 03:19 AM
