Float valve-$45
Old Jun 16, 2005 | 07:40 PM
midnite's Avatar
Default Float valve-$45
My dealer want's $45 for a float valve. Does anyone know where to get a resonable price on one?
Old Jun 16, 2005 | 10:58 PM
1wheel247's Avatar
Try Sudco. They sell alot of Mikuni parts. 45$ is total crap. Don't EVER pay that. Also, the 660 Yamaha Grizzly uses the same BSR42 carb as a DS and the carb parts are cheaper from the Yamaha dealer than buying from a Bomb dealer.
Old Jun 16, 2005 | 11:12 PM
CountryJoeGlass's Avatar
I think the pedator also uses the BSR42 carb.
Old Jun 16, 2005 | 11:18 PM
midnite's Avatar
Thanks for the info fellas.
Old Jun 16, 2005 | 11:42 PM
jackass650's Avatar
check here ronnies what are you calling the float valve? the needle and seat? ronnies has it for $21.73 for the set but they are calling it the needle valve seat,click on 2004 and then raptor then carburetor it will show the prices and exploded views, hope it helps
Old Jun 16, 2005 | 11:45 PM
1wheel247's Avatar
Ronnie's is the place to go for OEM
Old Jun 17, 2005 | 12:19 AM
midnite's Avatar
Ok, ronnies has a needle valve assembly {I've got a nasty gas leak out the bowl vent } for a grizzly for $29 + change. Better than $45 from my rip off dealer { world of power sports, decatur il }. I also needed a clutch lever, and was told bomb only sells the entire assembly lever + perch + wires, for$59.30. Thats basically $59.30 for a clutch lever!!!!!!!!!!!!!!!!!!!!!!!!!!!! Parts gettin expensive.
Old Jun 17, 2005 | 12:23 AM
1wheel247's Avatar
Check out "Whats in your garage" on this forum
Old Jun 17, 2005 | 02:24 PM
R00ST's Avatar
why not just check out ebay, stock carbs go for like 20-50 bucks for the entire carb assembly.
bmxatv10
Oct 14, 2022 06:23 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
