Which cams ?
Old Jul 15, 2005 | 02:47 PM
shmee's Avatar
Default Which cams ?
Originally posted by: OregonDunePatrol
Buy some Web 110's or Web 109/110's and put the money you saved into a TM45 with a pump.
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 15, 2005 | 04:21 PM
SCOUNDREL's Avatar
With swapping out the carb you will need a new throttle cable as well. I asked this question once before and never got an answer so I'll high jack this thread and ask it once again....When changing out the carb to a TM45 or Lectron I was told that you need to do modifications to the seat pan to allow for the top of the carb to fit properly under the seat. Is this correct? and what does it entail?
Old Jul 15, 2005 | 04:47 PM
OregonDunePatrol's Avatar
Scoundrel,
Yes you need a cable with a TM45 - They are inexpensive. A cable alone does not really work with the Lectron because the carb needs more cable pull than the TM45.
Seat pan mod only if your seat collapes down off the front mount. Takes about 3 minutes - cut a small square hole where the TM45 cable wheel is. Piece of cake ...
Marky
Old Jul 15, 2005 | 05:05 PM
CountryJoeGlass's Avatar
NO need to cut the seat pan with the lectron. You will need a new cable & billet thumb throttle with the lectron. I have a 44mm, 46HV & 48HV lectron carbs. I love the lectron carbs, I just need a set of duals now.
Old Jul 15, 2005 | 05:15 PM
  #15
shmee's Avatar
you dont need to buy a cable for the tm. get the little brass thing out of the stk carb and that will fit right in the tm.
Old Jul 15, 2005 | 05:16 PM
  #16
SCOUNDREL's Avatar
Sorry Joe but never could get used to those damn thumb throttles....[img]i/expressions/face-icon-small-blush.gif[/img]
I've been riding motorcycles most of my life and the first time I jumped on the DS I felt as if I have two left feet.....lol
Old Jul 15, 2005 | 05:24 PM
  #17
Sandragggen's Avatar
10-4 on dual carbs. I've had fairly good luck with my A1-A2's but have not tried any others....yet. I will admit that at first I didn't like the Lectron only because of the sticking and the long throw but since then I re-routed the cable and got use to the long throw.....everything is fine....it's a very simple carb. I'll be putting Lectrons on my Banshee.
JMiller
Old Jul 15, 2005 | 07:17 PM
  #18
MrMeaner's Avatar
The stock cable will work for a TM. Buy an alcohol kit from wood racing and put it on alcohol. It will scream and is very easy to use. If you dont want to run alcohol get the Lectron. They seem to hold tune. What I mean by that is once its right theres no rejetting with temp changes and altittude doesnt seem to effect mine like the TM. Just my experience with the two carbs. I like the performance of the Lectron but the price is painful. I would do a carb and loose the airbox before the cams. I think it will make a bigger difference
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
