Steering Stem Bearing (bottom)
Old Oct 3, 2005 | 01:31 PM
Entomber's Avatar
Default Steering Stem Bearing (bottom)
How did you manage putting in the new bearings? Also what really had me scratching my head is how do you replace those two O-Rings? Do you stretch them over the top of the stem?
Old Oct 3, 2005 | 01:57 PM
c5ls1vette's Avatar
Yes, you just stretch the o-rings over the stem.
Old Oct 3, 2005 | 02:04 PM
DuneRider650's Avatar
I ride a little here and there......
well....i never took my entire stem out just lifted it up about 9 inches from the bottom. To put the new bearing in i just put it in between the two washers at the bottom of the stem and clamped it together with there bolts but everytime i did this the bearing jammed 1 way or the other...just took allot of time.
Old Oct 3, 2005 | 11:00 PM
TheChosenOne's Avatar
the bearing will jam from sede to side yes... a hammer is a good convincing tool, just try to keep the bearing flat as you tighten it, and then tap the top of the stem to help the bearing press evenly into the flanges... works in the end, but still takes some time and patience...
2quiker
Mar 22, 2022 08:36 PM
antiguogrumete
Sep 5, 2015 03:41 AM
Polarisman1123
Aug 13, 2015 08:13 AM
Sportsman850
Jul 31, 2015 04:25 PM
1966F100
Jul 12, 2015 03:01 AM
