how many coils do i cut off
Old Sep 11, 2005 | 08:35 PM
22bomb650's Avatar
Default how many coils do i cut off
how many coils do i cut off of the carb spring
Old Sep 11, 2005 | 11:09 PM
DuneRider650's Avatar
I ride a little here and there......
3?
Old Sep 12, 2005 | 10:37 AM
Oldmanracing's Avatar
You need to cut your spring to an overall length of 3 1/8".
Older DS's had to be cut 3-5 coils to come to this length.
The new springs are 3 1/8 from the factory.
Do not go shorter, static height is 2 7/8, you need alittle load so slide does not bounce/flutter.
Old Sep 12, 2005 | 09:51 PM
22bomb650's Avatar
thanx
Old Sep 15, 2005 | 03:08 PM
ds650iceracer's Avatar
Oldmanracing,
Could you give me a rundown on all of the modifications you have made to the stock carb on your ds? I'm into endurance racing and do not want to invest in a carb that will increase fuel usage. Therefore, I want to modify my stock carb to make it as efficient as possible.
Old Sep 15, 2005 | 05:14 PM
TheChosenOne's Avatar
I cut 4 coils on my 04 bajax, didn't really notice any loss or gain, but when i had my carb off, if i gave it a little shake, I could hear my spring bouncing around inside....(i'll check, it could have been the float... and I'll measure the overall length with no tension on it to see what that is) I'll get back to ya on what I find....
Old Sep 15, 2005 | 05:40 PM
JMAC650's Avatar
04 and 05 springs are already shortened. No need to cut. My 03 I ordered a spring from an 05. It was cheap. I did the cutting the spring trick before and it worked great, but then I replaced it with a new spring.
Old Sep 15, 2005 | 09:23 PM
Yeah, my spring now dials in at 2.60 inches, and it is supposed to be 2 7/8 inches or 2.875 inches, so I'm too short. I never did read about the 04 springs already being shorter than the previous years when I made my cut, But hopefully for everyone else they will know before hand. Well, off to pick up a new spring..lol
Old Sep 17, 2005 | 09:00 PM
22bomb650's Avatar
my 02 spring is 3 1/8 " so do i cut it?
Old Sep 18, 2005 | 03:32 AM
If your spring is 3 1/8", leave it alone. It is fine as is.
On your spring is both ends closed, that is, last coil meets itself.
Or is one of the ends open,that is, the twisted wire does not meet itself.
If one end is open then someone has cut the spring already.
Or if both ends are closed, somone installed a newer spring.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
