Ace fab problem
Old Sep 14, 2005 | 02:31 AM
Scatterbrain's Avatar
Default Ace fab problem
Just a little warning about the ace swingarm. I have a problem with the carrier housing. Be sure to put some anti seize or grease on the outside of the carrier before you install it. Mine rusted on the inside and locked the carrier hard enough that I couldnt adjust the chain. It took me an hour and a half to free it up enough to adjust the chain. Other than that Im really pleased with the swing arm. I have pounded it hard in the whoops, jumped it with zero problems. Im thinking about painting the inside of the housing with rustoleum and using anti-seize on the carrier itself. Im going to give Chris a heads up on this maybe he can come up with somthing better.
Old Sep 14, 2005 | 02:57 AM
choosetolose04's Avatar
Thanks for the heads up. But, I would think of it just as good common sense to put a dab of grease on the bearing carrier before you install it into any swingarm. Ace done a fine job for me...[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 14, 2005 | 06:27 AM
atvaddict01's Avatar
.I would think of it just as good common sense to put a dab of grease on the bearing carrier before you install it into any swingarm
Stocker says to install in a dry bore.Or the chain will not stay tight
Old Sep 14, 2005 | 06:29 AM
OK, well then why does the stock arm slide and the ace arm dont....?
Old Sep 14, 2005 | 06:32 AM
If you buy me one and send it this way ill figure it out for ya[img]i/expressions/face-icon-small-happy.gif[/img]
Different metal maybe.
Old Sep 14, 2005 | 06:44 AM
Its on the way...[img]i/expressions/face-icon-small-happy.gif[/img] Yeah, probably the metal....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 14, 2005 | 11:56 AM
I did in fact put a little grease around the carrier. when installed it. evidentaly not enough . I was worried that to much would make it not hold the chain tension.
Old Sep 14, 2005 | 04:57 PM
donal's Avatar
Scatter, I keep trying to tell you to loosen those allen screws BEFORE trying to adjust that chain of yours!!!! LOL!!![img]i/expressions/face-icon-small-happy.gif[/img] After we talked on the phone the other night I went out to check mine and the carrier is free as can be...
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 14, 2005 | 07:15 PM
Nice shiny chrome i hope.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 15, 2005 | 01:35 AM
2BIG2BFAST's Avatar
Im waiting on my chain to arrive then i can tell you if mine will adjust. The shop put mine together so hopefully they did it right.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
