520 vs. 530 chain
#31
Sprocket Specialist can do it, custom made to order what ever tooth count Text Web Link
#33
Originally posted by: DSNUT
I wonder how many aluminum sprockets one would go through for every Ti-Moly sprocket?
Any one know the weight difference between the 520 Tri Moly Sprocket 42t vs the 520 Steel Sproket 42t?
Oh it would be 3 Aluminum Sprockets vs the Tri Moly on cost, Wear would depend on chain type, care of the chain, and riding styles, I have a aluminum rear with D.I.D. o-ring chain on my LT 500 thats over 10 years old with miles and miles on it and still in GREAT shape!
#34
Originally posted by: Scatterbrain
I run woods front and Sidewinder rear. Ive used a few alum. rears and I only get about two trips with them before their shredded. the Ti-Moly is near indestructable. My build is a 730 on the juice and I have pounded on them mercilously and there in great shape.
One of the best money savers for me.......
#35
I have a stack of completley hammered alum. sprockets. The sidewinder is still going strong. At around 65 bucks a pop for an aluminum one every few months, drop the 150 and forget about it! I couldnt get more than 2 or 3 weekends out of a aluminum sprocket. money well spent for me.
#36
Well it sounds like i should get the Sidewinder Ti-Moly.Do these weigh the same as a typical steel sprocket?Now i just have to convince the Boss that i really do need one of the Ti-Moly sprockets.I sure could save some $$$$$ if i stayed away from these forums.LOL.
#37
Ti-Moly will be lighter than steel that is for sure. It is probably slightly heavier than aluminum.
One thing I have found is that the aluminum sprockets last much longer if you run your chain slightly tighter than Bomb 530 spec.
#38
This is true! If you do this, you need to keep your chain in better condition than most do........way better than I do! lol
On the R1 bike I have to keep a very tight chain.......way tighter than I feel comfortable, anyway to keep sprockets on it.........but it works. I just replace it often.
#40
I also am going to do this conversion to my DS soon. I have a buddy that found out from Sidewinder that if you use all of their stuff they will warranty everything, especially the ti-moly stuff.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
520, 530, aluminum, atv, chain, difference, lt500, moly, renthal, sandaholic, sidewinder, sprocket, sprockets, ti, timolysprockets, types
