wont cold start
Old Oct 25, 2005 | 06:01 PM
OLDBOMB's Avatar
Default wont cold start
I have a 2000 bombardier and it has a very hard time cold starting i have been push starting after the engine warms up it starts very easily can any one help?[img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 25, 2005 | 06:19 PM
Majorecho's Avatar
sounds like your cams/valves are too tight and need to be reshimmed.
Old Oct 25, 2005 | 07:30 PM
ScoobyDFW's Avatar
also check your pilot jet. if stock carb from stock 2000 DS650 the carb is setup too lean at idle. the motor needs enrichment when cold.
Old Oct 25, 2005 | 11:33 PM
rfwlll's Avatar
I second scooby's advise. RUSS[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 26, 2005 | 06:40 AM
atvaddict01's Avatar
Might also be a weak battery.
Old Oct 26, 2005 | 07:07 AM
pads's Avatar
I second the weak battery. If my battery was down a little bit, it would crank and crank. With a full charge, it would hardly make 2 revolutions before firing. The valve check couldn't hurt at all either.
Old Oct 26, 2005 | 08:19 AM
Hightower's Avatar
all of the above,
you definitely need to keep the valves in check as with any 4-stroke because the valve gap decreases over time until ultimately one or more valves are not fully closing
and again true on the pilot, I upped my '01 pilot jet to a 45 from the 40 it came with and tweeked the idle mixture screw to boot.
a bomb, and alot of other quads too, cannot run with a dead battery cause the stator needs juice to excite the field coil, and a poor battery makes for poor running so if its old and doesn't hold charge it can be a problem.
Old Oct 26, 2005 | 09:21 AM
DuckysDS's Avatar
Where can you get the larger pilot jet ? Does the bomb dealer carry them ,I don't suppose you could remember the part # ? I know, it's alot to ask?
Old Oct 26, 2005 | 09:59 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
Check your spark plugs, if they are dark it makes for hard starting too.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
86atc250r
Jul 28, 2000 02:40 AM
