Bomb 800 Chip?
Old Nov 28, 2005 | 03:49 PM
RonM's Avatar
Default Bomb 800 Chip?
Does the 800 have a break in chip? Is there a large performance gain after 10 hours. I know the 2 stroke Ski doo's had the chip, but not sure if the 4 stroke bomb would have one.
Old Nov 28, 2005 | 04:12 PM
BRP33's Avatar
Yes they do.
Old Nov 28, 2005 | 04:43 PM
biggerisbetter's Avatar
please explain.
I guessing the ECM has an internally timer that will not allow over-rev or "full" power from the engine till 10 hours has been reached?
Bigger.
Old Nov 28, 2005 | 04:54 PM
RonM's Avatar
On the two strokes, the chip was programmed to run richer and retard the timing. At the 10 hour mark it was programmed to burn out.
Old Dec 11, 2005 | 11:19 PM
rich700's Avatar
DOES ANYONE KNOW WHAT MAX RPMS SHOULD BE?I HAVE 350 MILES AND MAX RPMS ARE AS FOLOWS-FOWARD LOW MAX 8,000 FOWARD HIGH MAX 6,500 AND REVERSE MAX 8,000. I DONT KNOW WHY I CANT GET 8,000 RPM IN HIGH. THANKS RICH
Old Dec 12, 2005 | 12:39 AM
200mph's Avatar
Have you taken it off any sweet jumps in reverse at 8,000 rpm?
Old Dec 12, 2005 | 12:49 AM
R00ST's Avatar
I will assume that was a napolean half-quote ^^ (that or a coincidence, but I think not lol)
That is odd if it revs to 8k in everything else, why it wouldnt in high. What does it show as your top speed in high revving out at 6.5k?
Old Dec 12, 2005 | 09:40 AM
MUDDY4LIFE's Avatar
I cant say FOR SURE but I have 280 miles on my 800 Max and I just dont feel any more power gains.With that said,I think this programed chip thing is not true.I could be wrong.
Old Dec 12, 2005 | 10:25 PM
rich700's Avatar
6,500 rpms and aprox 68 mph,anyone know what there max rpm is in high gear? thanks rich
Old Dec 13, 2005 | 06:20 AM
200mph's Avatar
Try running 7psi back and 5psi front and see what your top speed is after a full mile. Don't forget to tuck and keep it in 2wd. Also are you running 10w-40 synthetic or some 20w-50 thick stuff. Every little thing helps. You really need a GPS as your speedo could be off.
2many2ride
Sep 27, 2015 04:35 AM
Elkaholic
Sep 6, 2015 02:44 PM
BarryManilow
Dec 8, 2000 06:11 PM
bomberds
Dec 7, 2000 02:23 PM
