Popping back from Dumont
Old Dec 8, 2005 | 08:59 AM
Cammer's Avatar
Default Popping back from Dumont
So we had an awesome trip to Dumont and Armagosa. First ride back and I am backfiring and slight hesitation? It was cold (20 degrees) but other than that I haven't changed anything? So it pops and slighly hesitates under load, and only at high revs. I jetted down to DJ175 and lowered down needle one clip from top. Better but still backfiring, also plug showing a bit white on the tip. I don't really want to lean it out anymore, any ideas?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 8, 2005 | 12:06 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Check all connections where you could be getting an air leak from. One of your clamps/hoses may have vibrated loose.
Old Dec 8, 2005 | 06:42 PM
atvaddict01's Avatar
Have you ever rode when its cold before?
Sounds like my symptoms when i was running lean
last winter.
Old Dec 8, 2005 | 06:58 PM
Cammer's Avatar
Yeah last winter and it was fine! The only change I have made was adding the Dynojet kit this summer.
Old Dec 9, 2005 | 02:49 AM
BlackHawk's Avatar
Ya know, a DJ175 is about the same as a Mikuni 165 (stock.) It sounds like you are just lean in general, not to mention cold air is more dense, meaning you need more fuel. It sounds like you need to jet up, way up. Your needle should be somewhere between groove 4 or 5 (you are on #2) your main should be at least a 185 or 190 DJ. Do those two things and I bet it'll run a lot better. I hope you weren't running it that lean at Dumont, your DS sounds like a similar setup to my 2001 which runs a #185 or 190DJ main and the stock needle in the 4th slot as I recall.
Old Dec 10, 2005 | 01:06 PM
JSsDS's Avatar
Have you checked your valves lately? Could be tight on the intakes.
If not the valves then I agree with the "richen it up" consensus
Old Dec 12, 2005 | 01:11 PM
Cammer's Avatar
Before Dumont I ran DJ180 3rd clip hear at 5000 feet. At Armagosa I ran it the same and it ran great. At Dumont I put the airbox on and it ran ok. But since I came back it pops with the same jetting? I read Dynojet trouble shooting and with my symptoms they say I am rich so that is why I dropped the needle and jet size. Maybe I should go the other direction and see what happens? I checked for loose hoses to the carb and plug wires etc. everything seems ok. Could I have burn't a valve at Dumont by running it lean?
Old Dec 12, 2005 | 01:27 PM
DuneMe's Avatar
Check your battery. The connections can work loose sometimes and that can cause funny things. . . Usually I wouldn't describe it as popping but, worth a check as well.
Old Dec 26, 2005 | 11:08 PM
Cammer's Avatar
Dune Me I believe you were right, sort of. I took your advice and checked all my electrical connections. I am not sure but I think the cdi connector was loose. All is good again! Thanx everyone for your troubleshooting expertise!
Reactant
Mar 30, 2022 02:08 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
