battery tender?
Old Jan 7, 2006 | 11:30 PM
chirochris's Avatar
Default battery tender?
mrneg
i ordered that battery from your link, thanks...it sounds good--- charges and tends the agm battery..i went all over the last few days and nobody had anything....
do you charge it while it is connected to your quad...also once it is charged what do i use and look for to check the regulator..
Old Jan 8, 2006 | 04:17 PM
ScoobyDFW's Avatar
The best battery charger I ever had for small motorcycle batteries was the 6 amp Power Tender Plus
It can charge a DS battery that has gotten too low and it can maintain the battery during long periods of storage. The charging profile is designed for these types of batteries, unlike an automotive charger. I've used an automotive charger in the past but this power tender worked better.
Too bad my garage got broken into last year and it was stolen [img]i/expressions/face-icon-small-sad.gif[/img]
And the 545 Odyssey battery is a much better battery than the OEM one.
Old Jan 8, 2006 | 04:27 PM
Oldmanracing's Avatar
New Chargers
May be easier to find.
Old Jan 8, 2006 | 07:37 PM
Mrneg9's Avatar
Hey Chris. Yes I leave my battery hooked up on my Quad. After I ride I put the charger on and leave it that way until I ride again. The X charger maintains it automaticly. You will find that the ends on the battery charger are a pain in the *** to get on the battery while on the bike. (The clips keep popping off ) I trimed some of the plastic on the charger ends and bent the prongs out a little so they grab the bolts on the battery beter. You will see what I mean when you get your charger.
Once you have the charger and your sure that the battery it charged up all the way put it in the Quad. To check your rectifier start the bike with the volt meter attached. Rev it up to about 3000 rpm you should see the volt meter rise but it should not exceed 15 volts. If the reading stays the same when you rev the engine the Rectifier is bad and needs replacing. Hope this helps, D
Old Jan 8, 2006 | 09:39 PM
  #15
chirochris's Avatar
so if the volt meter doesnt move then i have a problem?
i thought it would move real high cause it is not being regulated...see what i know...nothing about electric
Old Jan 8, 2006 | 10:13 PM
  #16
Teebone56's Avatar
I have been using a shumacher tender for the last five years on my Harley battery, i have run into very few people with an 01 still using there original battery, mine is stll going strong I have one hooked up to the DS right now. I think I paid 29 bones for it. Well worth the money. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 8, 2006 | 11:21 PM
  #17
chirochris's Avatar
i have a gel battery so i need a special charger, thats the problem..had to spend the big bucks
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
