what ring gap for 14:1?
Old Feb 4, 2006 | 10:03 PM
yjacket2001's Avatar
Default what ring gap for 14:1?
Old Feb 5, 2006 | 12:15 AM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
http://www.jepistons.com/pdf/piston_instrc4032.pdf
Old Feb 5, 2006 | 01:34 AM
Sandaholic's Avatar
[i]Originally posted by: yjacket2001
Good assessment. 14:1 is high as you can go isn't it?
I think Mister HP bike at FSW last year was running 16:1 or so
Old Feb 5, 2006 | 02:40 AM
Hightower's Avatar
thanks OMR,
my piston is a CP rather than JE and has gapless second ring, the formula on that .pdf came very close to the CP specs, slightly different gap spec for the gapless seconds I have but close.
Very interesting reading on how application pertains to gap on that page also!
Here's an interesting read on pistons and rings - cast vs. forged, gapless rings pros and cons, etc...
http://www.carcraft.com/techarticles/77899/
Old Feb 5, 2006 | 09:25 AM
  #15
Old Feb 5, 2006 | 01:41 PM
  #16
OMR's Avatar
OMR
TOTAL SEAL
Minimum End Gap Requirements...
Application:
Min. Top Ring Min. Second Ring Oil Ring Rail
Street, Strip, Circle Bore x .0045" Bore x .0035" Min. .015"
Nitrous up to 150hp Bore x .006" Bore x .0045" Min. .015"
Nitrous over 150hp Bore x .008" Bore x .0055" Min. .015"
Blown Gas* Bore x .0055" Bore x .0035" Min. .015"
Blown Alcohol* Bore x .0045" Bore x .0035" Min. .015"
Blown Nitro* Bore x .0055 Bore x .0035" Min. .015"
* Indicates any type of forced induction system.
HOW TO FIT TOTAL SEAL
http://www.montac.com/mustang/ts1_ring_file.htm
Old Feb 5, 2006 | 03:00 PM
  #17
crazypainter's Avatar
OMR, you are truly a wealth of knowledge[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 5, 2006 | 06:10 PM
  #18
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Cast pistons are very hard compared to forged so they dont swell as much when heated. Forged is smaller at the top of the piston(where the heat is) because it swells more and is more plyable. The plyability of the forged piston allows it to withstand more abuse than a hard cast piston.
Example: If somebody shoots at you would you rather have 1 inch of glass in front of you or 1 inch of plexiglass. Think of NOS or detnation as the bullit.
Boomer84, I dont run CP pistons so I dont have any #'s for them.
Old Feb 5, 2006 | 08:07 PM
  #19
Old Feb 5, 2006 | 08:48 PM
  #20
Hightower's Avatar
Thanks OMR, that instruction link leaves nothing out, very educational indeed.
here it is clicky:
Joe454
Nov 20, 2020 01:19 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
